Fehlende Druckbare Teile
domryk
7
0
1
Hallo Leute,
Ich habe mir einen gebrauchten IFactoryOne gekauft und habe nun gesehen, das ein gedrucktes Teil defekt ist.
Leider finde ich dieses Teil unter "Downloads" nicht.
Gesucht ist die Obererechte Motor/rahmen Halterung.
Ich würde es ersetzen wollen. Prusa ist vorhanden für den Selbstdruck.
Kann mir jemand sagen wo ich diese Datei finde?
Mit freundlichen Grüßen
Dominik
Philippe Beuthe
6
0
1
Belgium
Hello domryk,
I received the One in July and on this latest version this part is not printed but is supplied by iFactory in solid plastic (it seems acrylic) 8mm thick.
This part fits into the engine mount, which is made of the same material, and which is therefore also different from yours.
I think this modification was made to give better resistance to fixing tensions, which are very important in this place.
The problem is that iFactory does not seem to deliver spare parts: I was confronted with this problem when I broke the two front legs with the pre-assembled version, which I do not recommend because it requires too much dangerous handling with a pre-assembled block heavy enough for the feet to assemble.
So I had to redesign a reinforced version, which I have just made available for free download on Thingiverse.
This is a real commercial problem that iFactory should address, because indeed, Prusa delivers without problem and sometimes even free of charge, spare parts broken during assembly by the customer.
And so yes, with this commercial problem, it is better to already have a first printer to print the parts of an iFactory.
You should therefore ask iFactory to deliver the broken part + the motor mount to you, because one does not go without the other.
Check if your part is 8mm thick. If not, it is better to replace the group of parts on the left and right so that the engine blocks are at the same level.
Good day !
domryk
7
0
1
Ok Thank you for the advise.
Can you post a link from the design at thingiverse?
I will try to print it first in ASA or so.
Philippe Beuthe
6
0
1
Belgium
As you know the ASA needs an enclosure.
For your health, you also need an air treatment: HEPA filter for an evacuation in the room, or an evacuation of the air to the outside.
domryk
7
0
1
Yeah i know, im very familiar with ASA :) but thank you.
So youre link dosnt work, Thingiverse reported a 404 error.
The team from iFactory was so friendly and send me the design of booth motor mounts and also they offer me to buy the mounts made out of very hard plastic.
So first i try to print it first.
